hpcbmw
Jul 21, 2020Explorer
Front hitch to carry motorcycle
I've got a 2000 F250 diesel shortbed with a FWC camper. The camper sticks out about 12" beyond the bed of the truck, just enough that I can't use a rear motorcycle hitch carrier/mototote without some sort of extension. The extension adds wobble and reduces carrying capacity enough that it doesn't look like it's a good idea.
I currently have a front receiver hitch that comes out behind the license plate of the truck. This is so high that my motorcycle on my mototote, and even bikes on a bike rack, are right at eye level, so too high to safely drive. To lower the height, I have to use an extension/drop system, again adding wobble and reducing carrying capacity.
I have an option to remove my existing front hitch and install one that mounts under the frame, so it's about 10" lower. Before spending the time and money on this option, I thought I'd see how well it works for others.
My questions:
1. has anyone used a front hitch for a motorcycle and if so, what problems do you run into? The bike I intend to carry is a CRF230l which weighs about 250lbs. Does this much weight on the front of the truck cause handling problems?
2. Has anyone used an extension/drop hitch system to carry a motorcycle or item of similar weight, and were there any concerns or problems?
3. Do you use extra headlights and turn signals up front, since the motorcycle is likely to block to these?
Thanks for any input!
My questions:
