free_radical
May 09, 2017Explorer
time2roll wrote:
I would still have the alignment checked. You should get a print with the measurements and the specs to verify yourself. With wear on the outside you are looking for toe to get close to zero and camber more toward the negative side of specification. There is always room for a tweak to make it better.
Post the measurements and specs for best comments if the shop just says all is fine when addressing the tire wear issue.
Consider a check with and without the camper to see if the weight is the real issue.
If the alignment is correct it makes no difference if truck is empty or loaded imo,,
If it did one would need to have the wheels aligned every time you put load on..or take it off,,which actualy one crooked mechanic sugested,to get more money out of me..
I suspect front tire wear could be from taking corners way too fast!?
44,057 PostsLatest Activity: Mar 12, 2026
