Grit_dog
May 10, 2017Navigator III
cpu266 wrote:
I have a Ram 3500 dually with cummins that was wearing the outside of the front tires. Two sets of front tires in 58,000 miles. Alignment was checked several times, it was on spec. This last time we took all the toe adjustment out. So instead of the front tires being set with the toe in it is now "0" no toe. Drives fine and no outer wear yet with 3,000 on new front tires. I check weekly with a tread depth gauge.
Be careful with 0 toe. Aside from it making the tracking a bit loose, it isn't the end of the world on tight newer components. 0 toe is not good once there's some wear or play in the front end.
I've read (on the interwebs) that Ram actually sets the trucks with a bit too much toe in, but I'd still want to be 1/16" - 1/8" overall.
44,057 PostsLatest Activity: Mar 12, 2026
