NorseNW's avatar
NorseNW
Front tire wear after 27,000 miles
First time truck camper owner. Arctic Fox 1150 on a 2015 Chevy DRW. Handles and travels great. Has about 27,000 miles on the truck. 3/4 of that is probably with the camper on. Half of that towing a boat behind the camper as well.
I was loading it up the other day for a trip and noticed the front tires have a significant amount of wear on the outside of the treads on both tires. Just curious if this is normal or if I need to be looking into some issue.
Thanks for input / experience in the matter
  • My Dodge 3500 goes thru front tires fast , no alignment issues , more a heavy Cummins and a locker rear dually , they like to go straight when you turn , steers fine just wears outside tread of AT tires
    I now rotate the front`s a lot - left front to right front and back
    Rears stay on the rear , just inner to outer
    If you put a worn front on next to a rear it will take that tire down as it gets a flatter surface on the , wears the good rear faster
    And I buy a new set of fronts when there gone , two sets of front to one set of rears
    Mountain driving takes a toll too
  • Align with the camper on, then it wears the tires when the camper is off.
    Rotate often, we did it at 5k miles, seemed to help.
  • Front end alignment. The camper is probably unloading the front end causing the problem. Have it aligned with the camper on.
