Tiggs
Sep 14, 2013Explorer
Front window leak/no gasket??
I have a new to me Funfinder that has a window in the front. It is protected from rocks and such with a hatch door that just like the doors that provide access to my pass-throughs.
After a very heavy rain, I found water had seeped in from somewhere and gotten a small corner of the mattress wet as well as a bit of the carpet. From the location, I'm guessing that "somewhere" is the window. I opened the window and where I expected to see a rubber gasket similar to those around the pass-through doors, there is none. There is a thin 1/4 inch strip of weatherproofing foam attached to the door itself.
I'm going to spray the window down today as soon as it warms up a bit outside to see if I can force a leak (unless there is a better way). If the water is making it's way around this foam insulation, how would you recommend making a repair? Should I replace the existing foam or look for rubber gasket material? This unit sat on a dealers lot and can't help but wonder if someone removed the gasket as they did the one tail light cover and the bumper end cap.
Thanks,
Carolyn
Thanks,
Carolyn
