You're all worried about the wrong end of the TT. If the TT is a flatback the vacuum created by them acutally tries to suck the TT backwards, so, as I did, install an air deflector to direct the air flow down the back of the TT in order to help it detach itself from the air stream, that's where the major drag is.
Some TT's like the Trail Lites and Cruisers are rounded down at the back top, and the bottom is angled in so air coming off of the smooth bottom is deflected up at an angle helping it break out of the air stream.
Airplanes are big in the front (although streamlined) and taper to a point for a reason, even though it seems like it would be better if the point was in front for no frontal air pressure.
