LVJJJ wrote:
You're all worried about the wrong end of the TT. If the TT is a flatback the vacuum created by them acutally tries to suck the TT backwards, so, as I did, install an air deflector to direct the air flow down the back of the TT in order to help it detach itself from the air stream, that's where the major drag is.
I've heard this...has anyone tried the airtabs? I think that's what there called. Was your deflector like the old station wagons used to have? Redirecting the air off the roof down to break up the vortex?
