mountainkowboy wrote:
Is there a formula for calculating it for a curved front TT? I called Coachmen to get the frontal sq' of the 192RBS during my researching and they don't have any idea. All they could tell me is "if it was flat it would be 56sq'" Well it isnt flat, in fact it's only flat to the end of the diamond plate then takes a curve to meet the roof. Anyone know???
As others have said, you do not deduct for any slope or curve to the trailer. Frontal area includes everything punching into the wind including the tow vehicle. That's using Fords definition of it, as I don't know if GM or anyone else even defines it, which is
"Frontal area is the total area in square feet that a moving vehicle and trailer exposes to air resistance." They also go on to say.............
"Selecting a trailer with
a low-drag, rounded front design will help optimize performance and fuel economy." I would not take that to mean you do a wind tunnel test of drag reduction due to slope or curve, and then deduct the supposed results? But thats just an opinion.
I would say a Coachmen 192RBS which has a 10'-3" advertised height and 8' width to be 82 sq ft of frontal area. If you want to split hairs just deduct clear area under tow vehicle/trailer, for say 8 sq ft roughly?
74 sq ft. But you better add back in the 3 sq ft for the rooftop air. 77 sq ft.
Now if your trying to justify being within some manufacturers frontal area limitation, say 50 sq ft as an example, by splitting hairs and doing reduction calculations, it would be way easier to just ignore all of it to begin with. I only say that because over the 10 years I have been visiting RV forums, when such a question comes up thats usually the case. If you're going to throw manufacturers recommendations to the wind, throw them and forget about it. Coming up with some type of half arsed justification changes nothing.
