when im hooked up to city water will the fresh water tank fill up? I noticed my fresh water gauge came to full when I did this? new to this situation? thanks
Some RVs have a valve to fill the tank, if it is open or leaks, the tank will fill. If the check valve in the water pump leaks, that too will fill the tank. Common problems.
