ford truck guy wrote:
FishOnOne wrote:
Grit dog wrote:
Seems alot of the Powerstroke guys think they need additives to save their engines...
Unless there's a problem you're trying to cure or you bought the wrong fuel for the weather, there is no need to add anything but diesel to your diesel tank.
Just so you know...
Link
OP,
I have ~215k miles on my Powerstroke and used a antigel fuel additive a couple of times that I recall when the temps got really cold. The last time was this past February, but even then it probably wasn't necessary.
One can read this in 2 different ways.....
1 - That Cummins engines NEEDS extra help :B
2 - That Cummins is gonna buy Power Service and they are amping up their business...
Either way, I wave been in Ford diesels from the 7.3.. to the 6.0 , 6.4, and now my 2nd 6.7 and have not used anything in any of them... I DID use the winter blend ( white ) Power Service in my old 1 Stack Mack, "R" Model back in the day...:C
Probably a third. Power Service is paying Cummins to endorse/recommend using them, and Power Service paid for the emissions testing with Cummins emissions equipment.
Many diesel manufacturers stopped recommending diesel additives with the 2010 emissions requirements due to their unknown effect on the SCR. Some testing shows that it may shorten the life of these components if too much is added. Additives may also increase NOx so they have to be emissions tested to use them with the new rules. Of course, no engine manufacturer is going to want to pay to test all these additives that they will make no money on.
However, if an additive company wants to pay for the testing and pay royalties on using your logo and recommendation then that is a no-brainer for the diesel manufacturer. Power Service probably went after Cummins since there are way more Cummins diesel's out there.
The need for diesel fuel additive depends on many variables like the quality of the fuel you are using(which is different from one place to another), temperature, how much idle time you are doing, and so on. A person in Texas or California may not need to use additives due to our fuel requirements being higher than other states that use the federal requirements. One person may idle a lot and needs additional protection while another may not. During winter months, a semi-truck or hot shot driver may fill up in a southern state where it is warmer and travel to a northern state where it is much colder since they can go 800-1200 miles without the need to full-up depending on their set-up.
I think some of the brand loyalists here see the word additives tied to their favorite brand as a sign of weakness when it actually is just dependent on how you use your vehicle and the quality of fuel available to you. Not everyone has the same situation so you will have different answers. Many people forget that others may not have the same situation as they do. If I were traveling to a region that was unfamiliar to me, I would definitely take some additives with me just in case I have to get fuel at a questionable place or traveling from a warm climate to a colder climate without refueling.
