ajriding wrote:
21 is pretty terrible mileage for a 2019 mid-sized.
Is this normal for a Ranger?
Yes, underpowered engine towing a big (think aerodynamic frontal area) trailer will suck the gas in, where a big v-8 truck will do better as it is not working so hard.
If you like Fords and towing, look at the F150 for 28 highway and will get much much better mpg towing, and the engine and trans is much more suitable for towing something this size.
You need a smaller trailer, or just live with the poor mpg. Research how to change your driving habits to get better mpg's too.
When I tow my cargo trailer with a similar truck to yours (cargo trailer is only 5 feet wide), I can get 16-19 mpg. It's not the weight, it's the aerodynamics that affect mpg.
Ranger took over for the F150 in size after the F150 was moved to share same cab/body as F250/350.
I would call it a large "mid size", slightly smaller than what the F150 was, the new "Maverick" truck sort of fills in for what used to be the old small version of Ranger.
SEE Specs hereOnly offered with the "baby" 2.3L ecoboost with 270 HP/310 ft lbs TQ and depending on cab configuration has curb weight of 4,200-4,300 lbs.
It is seriously underpowered for towing which means you will be seriously spooling up the turbos to the max gulping down a lot of fuel.
To put that HP into perspective, that is slightly more than a 2003 2V 5.4 with 265 HP and less than a 2006 3V 5.4 which offered 300HP that I had owned.. Both of those got far better towing fuel mileage and that was in full sized F250s with curb weights around 5,800 lbs.
Don't get me wrong, have a friend with a 2019 Ranger, nice good looking truck. Pretty quick empty but it really was not designed for good towing mileage in mind.
Part of the issue with mileage is often folks try to get up to speed as fast as possible and try to maintain highway speeds up grades. Towing requires one to realize that neither happens if you want to get good mileage when towing especially with a under powered rig.
Basically OP will need to start out easy and slow, let engine and transmission do their job without adding any more fuel than needed. Then when it comes to climbing hills allow the truck to LOSE some speed instead of pushing the gas down further.
The trick is to stay out of the turbos as much as possible without being a road hazard. Once you dive into the turbos the fuel economy is out the window.
Op should have a screen on their display that will show a graphical readout for fuel economy, they can use that to learn the sweet spot between speed and fuel mileage. Sometimes you add fuel when not needed (lead foot) and can back off slightly and still maintain your speed.
