elidodge
Sep 14, 2014Explorer
Fuel Filters
I have a 2013 Ram 2500 Cummins,Where are the better buys on fuel filters? do you always replace both at the same time? At 8,000miles and have 10% left ,Will I have to replace fuelfilters every 8,000 miles?
john&bet wrote:
Well I am not a 6.7, but a 5.9. I then have to wonder why I have not had an injector,CP-3 pump failure in the 10+ years and 172k miles with buying fuel in over 25 different states in that time. Oh and yes I still have the OEM lift pump running just fine as of 4:15pm est today. Also our school bus mechanic buys NAPA filters for our '08 6.7 power buses. No failures.
AH64ID wrote:Well I am not a 6.7, but a 5.9. I then have to wonder why I have not had an injector,CP-3 pump failure in the 10+ years and 172k miles with buying fuel in over 25 different states in that time. Oh and yes I still have the OEM lift pump running just fine as of 4:15pm est today. Also our school bus mechanic buys NAPA filters for our '08 6.7 power buses. No failures.
For anything 6.7 stick with Fleetguard, period. Nothing else is good enough.bobsallyh wrote:
NAPA Gold or Baldwin.
NAPA Gold should be called NAPA JUNK!! Wix, who makes NAPA filters, filters rarely meet, let alone exceed, the filter they cross reference too. The Baldwin's are generally good, but I am not sure Baldwin has the media to meet, or exceed, the tighter filtering on recent model year pickups.john&bet wrote:ScottG wrote:Whole heartily disagree. But then mine is 11 model years old and running just fine.
Don't buy cheap Napa, Orielly's, etc filters. Make sure they are either Fleetguard or Mopar (which are rebadged FG).
For your truck the NAPA, aka WIX, filter doesn't meet the min spec for Dodge which is looser than the min spec from Bosch. Wix publishes their filtration rated at 8um, when Dodge wants 7um and Bosch wants 5um. Wix will also not disclose their fuel/water separation rates. When they are asked why they don't make a filter that meets the spec their answer, on multiple occasions, is "we are close enough". On a fuel system that has tolerances as tight as 7um in places "close enough" is CRAP!!
Fleetguard and Baldwin are the only ones, AFIK, that make a filter that's meets or exceeds the Dodge spec. Baldwin/Hastings is the only filter I know of that exceeds it for your 3rd gen 5.9 at 5um.
ScottG wrote:
Yes, things have gotten arguably better though.
For years Bosch has been telling GM and Dodge/Ram that thier FI system needs 2~3 micron fuel filtering but the manufacturers have ignored them. This results in excess wear to injectors and shorter life. The newer filtering gets down to that micron level and has better water separation.
Still, it's a hard pill to swallow going from my $12 filter (though I do have 3u secondary filtering) to $120 FF's.
