Flashman's avatar
Flashman
Explorer II
Aug 27, 2017
Fuel tank size.
My fuel light came on in my new Ram 3500. I was near a diesel station so I filled it up - could only get 25 gallons in! It is a 31 gallon tank. Does this mean I have a 6 gallon reserve after the fuel light comes on?
  • My Ram is the same, when the light comes on I have about 6 gallons left. The range to empty is only an estimate. For those people that like to run them out, it keeps them guessing LOL.
  • Carry 5 gallons extra and run it empty to see how far it goes
  • 4x4ord wrote:
    When I'm towing a heavy load I can ignore the fuel gauge. I have to fill up at every freaking service station I come to.
    My old 82 Chevy 4+4 with a 454 and a Holly I used to say it'll pass anything except a gas station.
    When I used to drag race it on the weekends you could literlly watch the gauge going down.
  • 4x4ord's avatar
    4x4ord
    Explorer III
  • Mine counts down to miles left to empty. Then it says low fuel. At that point with a 32 gallon tank I get around 30 in tank.
  • My Chevy is about the same. I have run it to empty and it only takes 19 or so gallons in a 26 gallon tank (actual fill is generally 25 gal unless I dribble it in to the very top). Most of the time I fill at around 12-15 gallons or the 3/4 full mark.
    I can read the Display and it gives an accurate reading of how many gallons I have used-if I remember to reset it :)
    I considered the possibility that the tank had collapsed some amount (it is a plastic tank after all) but after checking as much as I could, without dropping the tank, I now believe the fuel level sender is just inaccurate.
  • My old Ford the light comes on and the over head display says 50 miles to empty. As near as I could fig it has 8 reserve but didn't push it. The sensor must be toward the back cause if you park front down it shows less fuel and if your level or front up
  • May be...may be not. And it's the same answer for all vehicles.
    Depends where the actual fuel pick is and conditions at the time.
    Better not the test the waters whenever possible.
  • Does your owner's booklet say anything regarding this? (Page 251)
