jimh425 wrote:
pjay9, you get to have the least weight rating of the following.
axle rating
tire rating (either 2 x tire or 4 x tire)
In some cases, the rear axle rating is more than the combined rating of the tires. That's common on the SRWs, but not on the DRWs.
The front axle rating is usually less than the combined rating of the tires on either a SRW or DRW. So, people generally run less tire pressure in the front since the load capacity is not required.
THX for your reply, clarification!
So to answer my question it would be 15000# for rear not counting axel rating...right? I get the axel stuff, just couldn't rememeber tire/wheel stuff!
