DieselBurps wrote:
Can't quite wrap my head around the idea of refusing a dually, but carrying a truck camper and also towing a large travel trailer. Bedlams idea sounds the most reasonable to me if I had 300K to spend on camping. One problem with the large TC though is I am not sure you are going to fit a 50" 4K big screen inside. The trailer would allow you to tow your batteries, but if there was a length restriction in the national parks and you were longer it would mean leaving the big screen TV behind.
The the trailer can double as a man cave and media room where you can have the entire front wall filled with television screen (8' wide ?). You should be able to tow a 20' enclosed trailer to most National Park campgrounds - There will be some areas where towing anything could be a problem and that's why you drop the trailer at a secure location and explore farther with only the truck/TC.
BTW: TC's can now come with 32" screens from the manufacturer and 40+" will typically fit that same location (we're getting there).
