EYEMLOST's avatar
EYEMLOST
Fulltime RV'ing-Truck camper; built-in washer/dryer Question
How desirable would a washer/dryer be in a truck camper that's going to be used fulltime?
Would it be worth it?
Meaning; reliable/reasonably low maintenance/actual washes clothes reasonably, etc.
I'm currently looking at the Host 'Mammoth' model truck camper which offers an over-under washer/dryer.
I plan on doing mostly boondocking/remote/primitive/off-the-grid camping (65%/35% ratio~).
Baseline of set up:
1) I'm single (meaning one person).
2) Truck will be Ford F-550 or F-600 4WD PS diesel.
3) Fulltime travel/touring of N. America from Idaho.
4) Will be Winter camping.
5) Will be traveling on mostly fire roads/back country roads/forest roads, etc.
6) Will only be returning to civilization to restock/replenish/or travel/change location.
  • If I was full timing in a TC, I would need to tow an enclosed support trailer for all the bulky/heavy stuff you don’t want in the truck or camper. That’s where I would put a small washer/dryer pair or a combo unit.
    I just can’t see the need to have something like that IN the truck camper itself.
  • In my humble opinion I would not consider a W/D
    1- added weight to haul
    2- severe shaking promotes breakage hence repairs needed
    3- washing by hand in the sink is easy for one guy.
    4- select non cotton easy dry fabrics for sheets and clothes.
    5- use a smaller towel
    5- more space to store your stuff in the camper
  • You’ll need a generator. How much water does a load use? What’s your fresh water and gray water capacities? Water is issue when boondocking. Bunch easier than laundromats.
  • While I don't have one, I can say, it would be a great benefit assuming all else is workable.
    Only concern would be the water consumption and gray holding tank capacity. I suspect that's been considered in the option and washing probably doesn't take much more water than a shower..
    Sounds good to me.. curious to see what others say.. thanks for posting..
