Hi welcome to the forum!
Here are a couple things you will need to look into BEFORE you leap into living in an RV and with dogs.
Many CG's have pet restrictions. Number of dogs, size, weight and breed of dog. Call the CG's in your area ask what their pet restrictions are.
Some CG's also have rules that pets are NOT allowed to be left in the camper unattended. I.E. when you have to leave for work.
Which also brings up the dangerous issue of leaving pets in a camper.
If the electric power to the park and/or the shore station itself goes out, air conditioner freezes up and/or fails while you are at work....the RV will reach dangerously high temps within minutes and becomes deadly for any pets left inside.
Hope this helps answer some of your questions.
Call and find out about the pet policies at the CG's in your area. AND also find out what the CG's are charging extra such as electric, maintenance etc for long term stay, before you invest $$ in an RV.
You might be surprised that stayin in your apartment may be less expensive and maybe your only choice with owning 2 large dogs.
Good Luck! :C
