HMS_Beagle's avatar
HMS_Beagle
Fun with a truck scale
I bought a truck scale off of eBay.
These are frequently advertised as wheel scales, axle scales, wheel weighers, etc. Most of them these days are electronic, but the MD400 is a mechanical one that you see from time to time. I paid less than $200, they are heavy and it cost about $50 to ship. It is readable to 20 lbs, claimed absolute accuracy is 50 lbs to 5000 lb load, then 1% of applied load to max capacity of 20,000 lbs.
With only one scale you need a wheel shim of the same thickness so that the axle being weighed is level. There will be a very small error if the other axle is not also blocked to the same height, but that can be safely ignored.
The results for my '99 F350 DRW 4x2 with Bigfoot 10.4E:
LF 1930 RF 2160 total 4090 GAWF 4550
LR 3500 RR 3640 total 7140 GAWR 7460
total 11,230
GVWR 11000
This is with nearly full tanks (fresh water, propane, diesel), full owner's outfit, but no clothes, food, people. As you can see I am just under on each axle (but will be over on the front with 2 people and the cat), and over on GVWR. This is a relatively light camper, no slides, no air conditioner, no genset. The "owner's outfit" I transferred from the old camper, about 4 armloads worth - I doubt it was more than 100 lbs.
I remain truly amazed at those who can put a 2 slide camper on a 3/4T pickup and keep in under GVWR - filled with helium maybe?
You can weigh the camper directly with the scale. By measuring the weighing points, you can calculate the CG too.
  • It would be a little hard to get accurate numbers on the jacks with just one scale. By weighing the rear tires you can get an idea of which side is heavy and how much - notice in my figures the right side is about 300 more than the left, not sure why.
  • I need to find someone with one of those so I can get the numbers on how much each jack supports. I know the slide side is heavy but it would be nice to know just how much.
  • Interesting to see the scales again. I used those in Ag Extension work for weighing loads of hay/grain/silage etc.
  • Yep, in 2005 they raised the GVWR to 12,800 for the DRW (1800 more than '99). Now (2013) you can get optionally 14,000. I think my camper weighs about 3500, if I had another 3000 in GVWR I'd be well under. A post 2005 F250 has a maximum payload of 3100 or less depending on configuration so I would be way over on that.
  • A modern F-250 - 2005 and later have a 10,000 GVWR when they have a crewcab and diesel engine. With the gas engine, they can have a significant cargo capacity.
    I think the DRW F-350 2005 and later with the 17" rims will have about 3,000 more GVWR than your truck.
    So yes the newer ones will carry a lot more. But still not the 4,000 pounds that some put onto them.
    Fred.
