TheHound
Nov 30, 2017Explorer
Mickeyfan0805 wrote:TheHound wrote:
Thanks for the suggestion Mickeyfan! As a total newbie I am not sure I would be able properly recreate the scene of the crime lol as I have zero point of reference in terms of how these tow and clearance of the vital organs. And you are spot on...the tail is also a concern. Funny thing is, there may not be a problem here at all but I have no way of knowing until we potentially get stuck between our two ponds. Yikes!
Generally, your vital organs will be ok (jacks would be your main concern) - as most are typically above the lower edge of the frame. I would suggest that your tail clearance at the peak of the hill is likely your biggest issue (and the most difficult one to solve it if is one. Especially if you buried the tongue on a utility trailer, I think you are right to think ahead about the tail clearance of a longer tt.
Do you have any sense of the depth of the dip and the distance from entry point to exit? Also, is it a pretty consistent frop and rise - or is it steeper on one side than the other. That info might give us a sense of how likely (and easily manageable the problem might be).
Right at the entrance heading down (or exiting) would likely represent the sharpest rise/drop. Moving up towards the cabin it is less steep but I lose some traction as there is not much gravel. Not so worried about that now with the truck. There is a level stretch between the two inclines as you pass the ponds. I should have shot a video, probably more helpful. Thanks for the insight.
44,056 PostsLatest Activity: May 04, 2014
