westend
Nov 30, 2017Explorer
Having seen this same scenario with driveways in different Arboreal forest areas, I'd suggest to do some work to your driveway. For most folks, it can be done at a reasonable cost. If you have connections to someone in that area with machines and/or trucks, it won't be that exorbitant, may be deductible from taxes, and will be a long time improvement. Anything else you do with that driveway will only be a band aid. If you have water issues at the end of the drive, you may have to use a culvert under the improved driveway. In my area +$200.
Compliments on the pictures posted, it sure helps to visualize the issues.
44,056 PostsLatest Activity: May 04, 2014
