sapperb
Jan 04, 2021Explorer
Old-Biscuit wrote:
Switch on furnace is dual purpose...It is On/Off for using when working ON the furnace (turn it off then it can't start accidentally)
It also is a Circuit Breaker that can trip if high amp load is sensed when using furnace
Normally that switch should be ON & Reset
Thermostat is the 'switch' that turns furnace ON
Set thermostat to HEAT Mode, Turn set point above room temp and you should hear thermostat 'CLICK' then shortly after you should hear Furnace FAN start
Atwood Furnace Service Manual
Pg 8 ---wiring diagram ---yours would be thr one on right or bottom one (2001 Vintage used a Timed Delay Relay)
Pg 16 lists Sequence of Operation
Pg 22 has break down of furnace components
Pg 29 Troubleshooting
Pg 39 Exploded View
Pgs 49-52 Part Numbers
Thank you so much for breaking it down. Going to print that out now. Then give it another shot today or tomorrow
44,072 PostsLatest Activity: Aug 23, 2026
