sapperb's avatar
sapperb
Furnace fan wont turn on 2001 Angler 8C
Still trying to post pictures. Took it out just recently for 6 days in the dezert. The heat (furnace) was working fine. Came home to unpack yesterday and check everything. I tried to turn on the blower motor for the furnace by using the little on and off switch behind the metal grate, like I was doing while camping with no issues. I checked all the fuses in the fuse block that is attached to the circuit breaker panel. The fuses look good and I even tried turning off and on the circuit breakers. Still nothing when I turn the switch to on. Is there a separate fuse or breaker within the blower fan box? I do have the power cord of the camper plugged into an AC plug. The battery in the camper is charged. Thank you for any effort on this issue.
  • Haha glad you got it working! Bookmark the info, your circuit board is on borrowed time.... :)
    Yes Sir!!!!
  • Most of the circuit boards can be replaced with a Dinosaur Electronics version. They are of much better quality.
    I would suggest writing down your appliances make and model for future reference. If you luck is like mine, items fail when most needed in the worse weather and time of day.
