sapperb's avatar
sapperb
Furnace fan wont turn on 2001 Angler 8C
Still trying to post pictures. Took it out just recently for 6 days in the dezert. The heat (furnace) was working fine. Came home to unpack yesterday and check everything. I tried to turn on the blower motor for the furnace by using the little on and off switch behind the metal grate, like I was doing while camping with no issues. I checked all the fuses in the fuse block that is attached to the circuit breaker panel. The fuses look good and I even tried turning off and on the circuit breakers. Still nothing when I turn the switch to on. Is there a separate fuse or breaker within the blower fan box? I do have the power cord of the camper plugged into an AC plug. The battery in the camper is charged. Thank you for any effort on this issue.
  • Yes, without thermostat, the furnace is not told to come on.
    Switch is there for maintenance safety. Turning it off shuts down furnace power so it doesn't come on when your fingers are in it.
  • enblethen wrote:
    Make and model of furnace?
    What is thermostat set at?
    Thank you for the quick reply. I am at work, when I get home today I will get the make and model. I didn't have the thermostat on. Now would that make it not turn on? If you see my intro a couple weeks ago, I am very, very new to Campers. again, thanks brother.
    Bruce
