babun
Jan 29, 2016Explorer
debsgonecoastal wrote:
Thank you all for your responses. Does anyone have a Cougar by Keystone? We have taken the rig into the dealer twice to be worked on under warranty. They say that they have checked all ducting and that everything is connected properly and there are no kinks or problems. However we tested the unit and it still took over 4 hours to increase the temperature from 44 to 70 and this morning the room temperature only increased 6 degrees in one hour. Hoping to find someone with information on Cougar to compare. Thanks again!
I have an older 2003 Cougar 5th wheeler {28 foot}. Here in mid Tenn,
last week, it was at 15 degrees over night almost every night.
the factory heater brings the temp. from about 60 degrees to a warm
72 in around 25 minutes.
The fifth wheeler doesn't keep the temps constant, too much air leaks.
You have air duct troubles. Do you FEEL the heat from all the outlets???
44,071 PostsLatest Activity: Aug 30, 2026
