marcsbigfoot20b
Jan 30, 2016Explorer
We need more info....
How cold is it outside? This will matter if your insulation value is not that great.
What is the temp of the hot air coming out of the vents? If it is only blowing "luke-warm" air then it will take longer than if the burner is functioning properly with nice toasty air.
Ducts leaking is an easy check.
Mine is 27 foot and 35K heater and in 27 degrees it only runs for a few minutes before it kicks off when set at 68-70 degrees. The only difference is mine is well insulated.
44,071 PostsLatest Activity: Aug 30, 2026
