DWeikert
Nov 09, 2016Explorer II
Just to clarify, when you say "off" is there a separate On/Off switch or is it just the temperature setting down to an "Off" label on the gauge? Mine has a separate On/Off switch and in Off it will not run. It will, however, keep running until cooled if turned off while the furnace is running. This tells me it's not an actual power switch but a soft off the furnace can ignore in certain circumstances. Perhaps a little contact cleaner (available at Lowes or Home Depot). Be careful though as contact cleaner can attack some plastics. Test it on a hidden piece of the thermostat to be sure.
44,066 PostsLatest Activity: Oct 04, 2013
