hhernandez13's avatar
hhernandez13
Furnace Troubleshooting
Long story short, i hope.
Suburban sf 35 f furnace
problem just started a month back in middle of some cold weather.
worked fine then one day just didn't start up again.
turned thermostat up , nothing.
turned thermostat of then waited a few hours.
furnace turned back on for one cycle and never turned back on.
repeated a few times to have it work, then wouldn't start at all.
pulled unit out , cleaned it from mud dauber nest. all clear.
hooked it up to external battery and propane and ran just fine.
checked wires coming from thermostat, got 13.43 volts on one wire shore power and the other had none.
coleman mach Thermostat turns on a/c and powers high / low fan. does not power fan when heat selected.
so do u think this is a thermostat issue or a wiring issue where one wire may have a break?
