If I follow correctly you can run the furnace while it's on the bench? Then when you put it back in the trailer it does not work correctly?
Before you buy a thermostat you might try a test of removing the thermostat off the wall and connect the wire on the terminal labeled R (or RW) to the wire on the terminal labeled W. If your theory is correct the Furnace should run and heat. Let it run for a minute then disconnect the wires and it should shut off. Now let it cool for a few minutes and connect the wires again. If it works flawlessly then you most likely have a bad thermostat.
