hhernandez13 wrote:
ill ck thermostat the way opnspaces suggested first. then go from there and ck regulator. my tanks are newly refilled and my stove works. so ill figure out a way to bypass regulator on trailer with propane line that has regulator that i used for bench test.
Burners may still work with a bad regulator. Either test the regulator or turn on your high volume burner(stove) and see if you noticed a difference between that and the other regular (2) burners.
That was my friends problem...
Happy trails,
