- cleojaycoExplorersounds easy enough thanks I think I'll try it
- GrandpaKipExplorer II
cleojayco wrote:
Is it that tough to re wire a new plug? or take it in for replacement? thanks for the input
Usually 4 screws and caulk/butyl tape. Pull out and take the 4 wires off. Put the 4 wires the same way on the new receptacle and reinstall.
Should be just as easy as it sounds. - LynnmorExplorer II
If this simple task is difficult for you, RVing will sure be a chore. - cleojaycoExplorerIs it that tough to re wire a new plug? or take it in for replacement? thanks for the input
- CavemanCharlieExplorer IIIWhere did it break ? By just looking at the pictures if the hinge pin broke maybe you could drill all the way through it and use a small bolt as a new hinge pin.
deltabravo wrote:
cleojayco wrote:
does anyone know how difficult it is to replace the plug
It's probably held in with screws.
It's probably held in with screws.- cleojaycoExplorerdoes anyone know how difficult it is to replace the plug
- SidecarFlipExplorer IIIProbably not. You'll have to buy the entire plug from Furrion.
44,068 PostsLatest Activity: Jun 27, 2026
