Pmacjoh1's avatar
Pmacjoh1
Fuse box
Hello, I'm looking for help! I have a 1998 Artic FOX 22H. The Manuel states the fuse box is located in the electrical control center. But doesn't say where that is! Does anyone know where it is located?
Thanks
  • Go outside and see where your feed cord comes in and the panel should be fairly close to there.
    Guy
  • Ok, found it! The circut board & fuse box is under the jackkife sofa.
    Thanks!
  • Should have a small panel with 120 volt circuit breakers. The 12 volt fuses are located next to them behind small metal plate held on with thumb screw.
