_DJ_1Explorer IIMar 14, 2014Fuse size?I need to put a fuse in the positive line between battery and solar controller. I currently have 100 watts but may go to 200. Will a 30 amp fuse be enough? Thanks.............DJ
time2rollNomadMar 14, 2014Morningstar calls for 125% of controller output rating.They refer to NEC compliance as the reason.Wire must also carry the fuse rating.
Related ContentFuse panel locatewhat size fuses?What size fuseQuestion on fuse sizeFuse size question.
