I need to put a fuse in the positive line between battery and solar controller. I currently have 100 watts but may go to 200. Will a 30 amp fuse be enough? Thanks.............DJ
EVERY wire hooked to the positive post of the battery needs a fuse in it. It doesn't matter what the other end is hooked too. A short will cause hundreds of amps to flow from the battery which causes fires.
Even at 200 watts your controller won't put out more than about 18 amps.
