Gjac wrote:
These have been very informative posts for me having never camped in a TC or even owned a truck. My thinking for a TC was that I could always use a truck as a second vehicle. I also noticed most of you have DRW trucks. Did purchasing this kind of truck for other uses factor into your decision for the truck and a larger camper? If you did not require a DRW for other uses at home or farm use would you have purchased a SRW truck and a lighter camper? I have been driving for over 50 years without one so my only reason would be to haul a TC and maybe some firewood.
I grew up with pickups and only had a hiatus when I was stationed overseas (even though I wished I had a truck there too). For over 30 years I have owned a boat or trailer, so a truck has always made sense even though some of my cars also have occasional towing duty. I am on my fourth truck and each time I replaced one, it was for a bigger one. My last upgrade was to a Ram 5500, so I hope my growing has stopped and any replacement will be like or smaller. In the case of my current truck, I needed something that could carry the largest of truck campers and still have capacity to tow a heavy trailer full toys behind it. On occasion I remove the camper from the truck to do other tasks, but find most of the time I do not have to. I bought this truck rather than a motor home because I wanted the smallest foot print that could haul, tow, have sufficient chassis clearance for logging and service roads and have 4wd for poor conditions. My truck is not a daily driver, but I still work full time and usually commute by motorcycle and bus.
Whether you choose a DRW truck will depend on how big of a camper you want. You should be looking at campers with 3000 lbs or lighter dry weights if you want to stick with a SRW. This will keep you under axle capacity, close to tire and rim capacity and yet still be over the gross vehicle sticker. If you are trying to stay under all the sticker weights or want a larger camper with more room and amenities, you need a late model DRW truck.
