campn4walleye's avatar
Jan 01, 2016
Garage ceiling clearance
Happy New Year fellow TCers!
As usual I'm coming to you for your expertise. We are considering a home that has the Taj Mahal of sheds. The problem is it only has 12' doors. Our TC is 12' 3" tall on the truck. We have the options of putting it on a dolly and rolling it in (UGH!) or changing the AC unit to a lower profile model. We wouldn't mind doing that as our current unit is overly large and high powered. The current unit is 14". The Coleman Mach 8 is 8" which should make things better.
Here's the real problem: say we get it in, can we raise it off the truck in a shed with a 13' ceiling. We've never measured how high the camper is when at it highest point needed when removing the truck. Have you? We think it raises about 6". We cannot test it as it's in storage for the winter. Can it be done? How many of you roll it in on a dolly? What are the challenges and how do you handle a lip at the edge? Our TC weighs at least 4000 lbs without water.
Any info would be great.
  • I believe the OP is looking at a shed that has already been built.
    One thing to make sure of. Is the door opening actually 12 feet?
    I have a shop building with 12 ft doors but the actual height of the door opening is 11 ft 10 inches due to casing around the door opening.
  • I have a hunch a lot of us have owned TCs. I owned 3 in my lifetime. As I got older I moved to 5vers and MHs for more room on longer trips, and just too old to climb up into the bed. If you move out of a TC later 12' isn't going to work. You really need a 16' roof and 14 by 14 ft door. Plus selling that home later I doubt the 12' door would have that much to offer to another RVer. Just something to think about.
  • You should be safe using the 6" lift figure. I have some centering guides that I lift mine to clear while loadong/unloading that amounts to a 5" lift. Personally I like your idea of replacing the A/C unit and would be interested to read a step by step commentary as to what you ended up doing to install a lower profile unit, (hopefully you can find one with directional registers). Good luck.
