wilber1
Jun 29, 2013Explorer
transamz9 wrote:wilber1 wrote:transamz9 wrote:wilber1 wrote:transamz9 wrote:
Do a little tuning on the diesel and then there is no comparison,none, notta. And yes it will hold up to it with no problems.
Not quite. I have an Audi with a 2 liter turbo direct injection gas engine. Stock it puts out 211 hp and 258 lb torque. The peak torque is between 1500 and 4200 rpm. To match that torque and hp per liter displacement, the latest DM, PS or Cummins would need to put out over 700 HP and 860 lb torque. I can go to an Audi dealer and get a Stassis ECM program and exhaust with full factory backed warranty and boost the output to 270 hp and 328 lb torque. To match that output per liter
the diesels would need to produce 900 hp and 1100 lb torque.
Yes, I completely agree diesels make for better towing and I love my Cummins but today's gassers aren't your grandpa's gassers.
Okay, you look at things that way, My truck is right at double the weight of your car and with a tune I can well over double your hp and have 3 times the torque.
I have a gasser in the garage that probably weighs less than your Audi and stock it has 130 more hp and 72 lb feet of torque than your Audi would even after the tune. Came from the factory like that.
This thread is really pointless because a gas and diesel will never have the same specs.
I have a gasser in my garage that puts out 160 more hp and 200 lb ft more torque than my Audi but it has a carburettor and displaces 7.2 liters.
So, it's not stock.
Bone stock. 1966 Chrysler 440 TNT. Factory rated at 365 HP, 480 Lb ft, if you believe the factory ratings from those days.
44,066 PostsLatest Activity: Mar 14, 2015
