Hannibal
Jul 06, 2013Explorer
Why not say 5mpg for the gasser and 17mpg for the diesel. I get 8.5~ mpg with the gassers and 10.5~mpg with the diesels towing over the same routes at the same speeds.
For the cost of a ticking fuel injection system on a newer diesel, I can toss in a new long block and transmission so the cost savings is a gamble in the long run. The 100k mile warranty goes poof at around four years with me.
Not to forget the cost of DEF, fuel filters and special fuel conditioners for the delicate HPFP.
I haven't been banned from buying my 7th diesel. As it is, the only real practical benefit I see is 30% lower rpm. And that's only if you're erroneously afraid of a gas engine running in it's normal rpm range. 3800rpm is peak torque rpm with my wheezing 5.4L grocery getter. It can run there all day under load if it ever needs to without worry. As it is, it's only an occasional sprint at that rpm. On flat ground we run 2k rpm in O/D and 2600~rpm against any breeze or slight incline. Not a problem.:B
Why do people gear their diesels like a gasser so it'll run like a diesel? Why not a 3.08 rear ratio to put it at it's 1600rpm torque peak?
44,067 PostsLatest Activity: Jun 05, 2026
