Grit_dog
May 09, 2018Trailblazer
APT wrote:Dick_B wrote:
We have a 2011 Chevrolet Suburban 2500 with 5.7L (corrected to 6.0L) engine and six speed transmission. It struggles to pull my 7500 lbs. It can't stay in cruse control on anything but an absolute flat highway. I get 9+ mpg whether towing or around town. The only time the mileage is decent is when on the highway which I never am.
If I had to do it again I'd buy a pickup truck and put a back on it.
Your experience while valid is an outlier of statistical data. I have never heard anyone else comment as negative as you about GM's 6.0L/6-spd combo. That makes me believe you can change something to improve your experience or you can change your expectations. I would first recommend using the transmission's tow/haul mode and M5 or M4 depending on terrain and target speed. For naturally aspirated small block engines, you should keep the engine above 2500rpm when cruising and 3000-5000rpm for accelerating and hill climbing. The 6.0L will do that comfortably for 300k miles.
I tow my 6500-7000 pound TT with the same 3/4 ton Suburban at 65-75mph in 5th and 4th gears (sometimes 3rd for hills) for both in state weekend camping as well as a couple 2200 mile trips through Application Mountains. I do this with 3 rows of comfort and sleeping family. We used our Suburban as a daily driver and main family vehicle for 100k miles. We get 13mpg in mixed commuting in the summer and 12mpg winter.
I expect Ford's 6.2L to be negligibly different in all aspects. Peak torque and HP are at similar engine speeds. Transmission gearing is almost identical so you'll be in 4th ad 5th gears towing anything high walled.
Statistical data? Would that be rvnet statistics?
This is good stuff.....keep it coming!
One guy thinks switching from a sub to the virtually same pickup truck will yield differnet results and another talks about how well it tows without mentioning the towing mileage and then inserts empty mileage in the same paragraph for effect?
BTW, I am in no way dogging the 6litre GM, but some of y'all would defend your rigs' virtues to the death!
#traditionaltrickiness
44,068 PostsLatest Activity: Jun 14, 2026
