windhorse's avatar
windhorse
Gas fridge on the move?
We have been driving our 1996 Lance Legend truck camper with the Dometic ac/dc/gas refrigerator/freezer on - until today, when, as we got to CO, the fridge started to switch itself from “gas” to “check” (ie off), so we stopped to consult with a technician, who told us some things we did not know:
- yes, altitude can effect the performance of older model gas/electric refrigerators
- yes, it is possible to enhance the performance at higher altitudes of older fridges like the one in our truck camper by having a qualified technician bore to a slightly wider size the hole the gas passes through, to increase the flow of gas and thereby improve the reliability of the gas powered operation of the fridge up in the mountains, though this would be an irreversible modification, resulting in use of more gas than necessary after we returned to lower altitudes, and, thirdly:
- no, you should not drive with the gas-powered fridge on!
This last point came as a surprise for us, as we have been driving with the gas-powered fridge on for thousands of miles… gosh, does this mean we are just lucky not to have had any problem apart from the fridge switching itself from “gas” to “check” today?
Are we the only older (though prefer the term “classic”) truck camper owners with a fridge like this one who drive with it switched on?
  • Why not just turn the fridge off during travel? Things should stay cold for hours if you keep the door closed.
  • You received incorrect advice.
    For higher elevation, the air is thinner and combustion engines need LESS gas. For higher elevations, gas jets should have a smaller diameter. Drilling one out is absolutely incorrect.
    As you already know, you can drive with the refrigerator working on a propane flame without issue.
    Did the tech at least help with the issue of the unit turning off?
  • We camp at 8700' elevation quite often with truck campers and 5th wheel trailers with LP fridge. Never a problem.
    Our first truck camper with a LP fridge was in the '70s.... and all three 5th wheel trailers we've had since we travel with the fridge on LP just as they were designed and advertised to do.
    Sounds like the tech needs to be re-schooled on the LP/12v/110v fridge.
  • Except for tunnels, ferries and fueling up ours is always on.
