Does anyone know if steel braided gas lines are ok to use? I need to run new lines from the black pipe, and plan on using pre made stuff from menards. Thankyou
Now that you have decided to use copper, make sure you use flared fittings only -- no compression fittings. Compression fittings are prone to leaking when stressed.
