shasta24
Feb 21, 2014Explorer
Gas line
Does anyone know if steel braided gas lines are ok to use? I need to run new lines from the black pipe, and plan on using pre made stuff from menards. Thankyou
nomad297 wrote:
Now that you have decided to use copper, make sure you use flared fittings only -- no compression fittings. Compression fittings are prone to leaking when stressed.
Bruce
