BenK
Apr 05, 2018Explorer
Guesses...
Suggest checking/flushing all fluids, as they may have gone past their useful life
Bearings...sometimes they start going slowly...creating drag
Be sure to have them explain any codes that comes up and note them on the work-order.
Good luck !
- Seasonal change in fuel mixture (additional of alcohol to the blend) that will take the computer time to re-learn HOW2 meter
- Tire PSI getting low
- Intake system and exhaust system...sensors might need cleaning (careful, follow directions from your manual and bottle of cleaner...some will ruin the sensor)...plugging up exhaust system...mainly the CATs...more so if you have used additives NOT good for the CATs...intake air filter needs change
- Basic tune up needed...plugs, even the expensive platinum wear out
Good luck !
44,066 PostsLatest Activity: Apr 10, 2026
