Cardno7
Nov 06, 2015Explorer
Gas mileage
Pulled boats for many years, now have a Rockwood Minilite 2014s. Pulled by Ford F150 Lariat. Gas mileage went from 16 mpg to 8mpg. Just want to see if this is about the average drop in mpg. Don't see ...
Slowmover wrote:
..snip.....
WDH adjustment should be a minimum of 100% FALR. TV brake drag and alignment should be checked. TV tire pressure should be according to load once WD is proper and each wheel position is weighed to find heaviest tire load on each axle (then to TV manufacturer guidelines; "more" is not better).
Fuel and campground costs are he honest daily expenses while en route. Worth your time to find the range of WD adjustments on a scale that your rig will see with varying loads. And to tighten up the rest.
