Rwake901
Jul 26, 2019Explorer
Gas Mileage
I have a Chevrolet 3500 6.0 gas to tow our fifth wheel. Has anyone tried using Premium gasoline to see if your gas mileage would change? Just curious. Thanks
dodge guy wrote:Lynnmor wrote:azdryheat wrote:
Octane has nothing to do with mileage.
It sure does if the knock sensor detects knock and the ignition timing is adjusted to compensate.
Yes it does. I proved it on my V-10 Excursion. Used to run 87 and power and mileage were down horribly! Switched to 93 and it improved. The. I got a tune from 5 star for 89 octane and it was better. My truck was over maintained so it was running 100%. You may not see a lot more mileage but you should feel the performance.
OP. Only you can decide. Run 2 tanks while towing and see for yourself.
