bo57ford's avatar
bo57ford
gas plumbing
anyone know where I can find
a gas plumbing diagram
  • vic46 wrote:
    bo57ford wrote:
    the gas stove works fine is the only one reg
    Perhaps if you were somewhat more candid about what your issue(s) is there would some assistance forthcoming.
    I'm just sayin!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    I'm betting he is posting from his phone. You know how that can be.
    If your stove is working and there is no smell of propane or observed leaks, the pressure in the gas line to the furnace should be the same as the rest of the system. Some furnaces can be problematic to start because there may be trapped air in the gas lines. Sometimes, a few attempts are needed before they will fire and run. There is also a list of other troubleshooting items. If you post what model furnace you have, someone may be able to share the service manual (including the troubleshooting guide).
  • Yes there are several tees. Gas pressure is controled by the regulator. To determine if its working or not requires a pressure test by a qualified service person. Or you could just throw new parts at it and see what happens
  • I dont think Iam getting enough pressure
    to my furnance is there a tee in the pipe
