big_russ
Sep 07, 2015Explorer
hohenwald48 wrote:big russ wrote:WyoTraveler wrote:
Watch the ignighter while your wife throws the switch. Are you getting spark? I'm not sure, maybe there is a reset if the tank gets too hot.
it has what seemed like two reset buttons ,it didn't work.what ignites he gas and how does it know when to ignite?
The gas is ignited by a spark generated by the control board when the thermostat says the water is cool. The control first opens the electric gas valve then generates the spark. It then monitors the flame (via thermocouple) to insure it has lit. If it has not, it will shut off the gas valve.
ok switch on control panel is on, LED indicator light is off., I have gas.its not firing .what could cause it to not fire after firing it on a dry tank?
44,066 PostsLatest Activity: Apr 16, 2026
