Jcrx7 wrote:
Wife and I will be full time living in our new travel trailer, navy style showers arent an option.
Has anyone installed one of these in a travel trailer? How about a washer/ dryer?
Perhaps "full timing" isn't for you?
If one was smart, one would realize that you CAN get a pretty long, hot shower with just a 6 gallon water heater without going to the extremes of a "navy" shower.
Are you going to get a sticks and bricks pasting you to the shgower walls, no..
How it is done..
Start hot water at low pressure, once hot you add a small amount of cold to cool the water. You ONLY want enough water coming out to create a "fan" from the spray head.
When done correctly you are mixing 1/3 hot with 2/3 cold and if you set it correctly you are using less than 1/3 gallon of water per minute.
This results in THREE MINUTES for each gallon of hot water..
6 gallon hot water tank will result in giving you 18 minutes worth of hot shower..
Washer/drier, some folks have installed them but many downsides to them like using a lot of water, taking a long, long time for one load (3 hrs) and they are pretty small so you will be doing a lot of very small loads..
To me, neither tankless water heater or washer/drier is worth what they cost..
