SO when looking at a transfer tank for diesel fuel knowing the alum tanks are quite a bit more expensive, what is the average life of a tank that uses diesel vs gas and steel vs alum.?
I was looking at the http://www.tractorsupply.com/tsc/product/delta-steel-transfer-tank-37-gal?cm_vc=-10005
this one a steel 37 gallon tank for 300 bucks.. I was going to pipe into the fill tube with bulkhead fitting and elec solenoid valve that is normally closed.
the plan was to fill both frame tank and bed tank and when frame tank get to below 1/2 open the valve to allow fuel to flow into tank.
I did read one place someone get a Check Engine light come on doing that.. it was something to do with fueling while running? this was on a ford SD I think older pre 2000 year.
thanks
