I was going to use an elec valve to control the fuel flow so when not flowing the valve would be shut off. This should allowing the system to perform its vacuum function and prevent the CEL right..
how often does the system do this vacuum to check for open fuel cap condition? it seems if you had a 1/4 or lower tank it would take longer to get a 25 gal tank to vacuum than one 1/4 full.
I would guess the system performs this test say at startup or after seeing the fuel level gauge go up maybe..?? I am not sure.
SO Denny you have a valve that closes after you allow fuel to flow and that prevents the CEL for open gas cap you are saying.??
Denny & Jami wrote:
I've been using a older version of this tank sense 95 (third truck) Tank. I pump it out of the tank with a Holley roitory vane pump and isolate the tank with a solenoid valve, I have a fitting silver soldered into to fill pipe so I can transfer going down the road without stopping. I used to vent it into the trucks vapor system but I would get a open gas cap light so now with this truck so I just have a filter on the vent hose, the tank has a rollover valve built into the vent outlet.
The truck doesn't pressurize the tank it pulls a vacuum on it every so often to check the gas cap. When you install a aux tank and when both the aux tank and main tank gets low it takes to long to pull the slight vaccum so you get the light, the rest of the time the tank vents through the recovery canister to open air. You just have to isolate the tank when not transferring fuel.
Denny
