wilber1
Mar 13, 2020Explorer
time2roll wrote:wilber1 wrote:Yes and the Tesla can go further on $100 of fuel.time2roll wrote:
Yes thanks for the HS chemistry lesson. All of the gasses contained in air go through the combustion cycle and a few things are created besides CO2 and water vapor due to the heat. Some of which are considered pollutants but that was not the point of the video. Gasoline contains some nasty stuff also but that is not the point either.
My point is the battery in and to itself releases the stored energy. Nothing else required. Gasoline needs to be fed oxygen from some other source to burn and release energy. My point is that all the elements to get the energy from that gasoline are not contained in that gallon jug.
Yes but from a practical point of view, an ICE vehicle getting 30 MPG requires less than 70 lbs of fuel to go the same distance as a Tesla S 85 with a 1200 lb battery. With 140 lbs of fuel, it can go twice as far.
Choose what you prefer.
Not much good if you can't carry it and that is why there will be no medium or long haul electric aircraft. Yes, it is a matter of choosing what best suits your needs.
44,071 PostsLatest Activity: Aug 30, 2026
